Sub suggestion
Any input on the options for the GCON sub?
Flatwound coils have better heat dissipation because they have more surface area. Most of that stuff seems more competition oriented. If you're running higher power on these, you may opt for the cooling options. Idk if I would do the extra spider because of it's affect on music. I'm not sure what the lead wire upgrade actually changes.
It’s easiest to communicate with ssa on Facebook messenger. Like everyone else said their subs are very conservatively rated. I was giving mine over rated power and it definitely wants more. Took it out till I do a build that can give it the power it needs.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
469
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
321
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
466
Masted85
CarAudio.com Recruit
Masted85
Alabama
Marve_Lous
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
