Sub sonic filter
I keep hearing it is a bad idea to use it and it should always be on off. I have a 12 in a sealed box. 1000 alpine on a rf p3 should I not use the SF at all?
You may be thinking of the bass boost when saying that some people have siad it is not to be used. . The SSF should be used in certain applications.
But you wont need it running sealed.
Its labled bass EQ.
Sounds like bass boost to me -- which you don't need IMO.
The SSF cuts off the signal below whatever frequency it is set. It's used when you have a ported box, especially one that is tuned high. It will indicate a range of frequencies on the dial.
The bass boost increases the signal of a certain frequency -- you don't need want to use that.
Thanks for the help bro.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Its labled bass EQ.
//content.invisioncic.com/y282845/emoticons/yes.gif.2d6d3882a589966b8145fbc57db57f33.gif
//content.invisioncic.com/y282845/emoticons/yes.gif.2d6d3882a589966b8145fbc57db57f33.gifAnd when it is a subsonic filter it will usually be labeled as such. Occasionally you will see an amp that marks it as an 'Infrasonic' filter. Same thing. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Fine Vol
Go Vols
Fine Vol
ROCKLEDGE, FL
Prowler573
