Sub set suggestions
PhDDevice
I'm looking two buy some new subs with a budget of $300 (give or take). I have a Lanzar 1800 Watt Monoblock Mosfet. I was thinking of buying 2 15" RE Audio SRX15D4, or 2 15" Earthquake TREMOR-X154. The REs would cost me $130 dollars each leaving about 40 bucks for a box, the Earthquakes would cost me about $120 each, leaving me 60. Of course I can probably gather a bit more money. With the Earthquakes I would have more left over to spend on an enclosure. Then again I am new to car audio, so I would like to know what you think the best set of subs, enclosure, and how I should wire them. I definitely need two 12 or 15 inch as the car I am dealing with is huge. I mainly listen to rock/blues, however ever once in awhile I will listen to the more bass heavy genres.
Tell me what you think, and I appreciate your help.
I'm looking two buy some new subs with a budget of $300 (give or take). I have a Lanzar 1800 Watt Monoblock Mosfet. I was thinking of buying 2 15" RE Audio SRX15D4, or 2 15" Earthquake TREMOR-X154. The REs would cost me $130 dollars each leaving about 40 bucks for a box, the Earthquakes would cost me about $120 each, leaving me 60. Of course I can probably gather a bit more money. With the Earthquakes I would have more left over to spend on an enclosure. Then again I am new to car audio, so I would like to know what you think the best set of subs, enclosure, and how I should wire them. I definitely need two 12 or 15 inch as the car I am dealing with is huge. I mainly listen to rock/blues, however ever once in awhile I will listen to the more bass heavy genres. Tell me what you think, and I appreciate your help.
look into 1 good $160 sub and spend $140 on a box designed and built for the sub..
PhDDevice
PhDDevice
United States
quackhead
Mike Mccabe
