metalhdmatt
my amp is a cadence ultra drive z7000, 1 OHM stable. 1000@2OHM, and 1500@1OHM. so im wanting to get as close as possible to 1 OHM for max watt out put from amp correct??? so i know my OHM's, no problem there, NOTE: im running 3 subs, "all i can fit, without building some crazy *** box that i dont want to build", unless you think i should do 4 subs bc i can get to 1 ohm with 4 subs... anyways back to Q; the closest i can get with 3 subs to 1ohm is 1.34 ohms... using either 2ohm dvc or 4 ohm svc sub woofers, which is better or does it matter? and #2 Q; if amp is pushing close to 1500watts, does than mean each speaker should not go over 500 watts a piece or can i do like 700watts a sub or more??? thanks a bunch.
