Sub power help
  • 5
I’m running the gauge wire that comes with a amp install kit I don’t remember what gauge it is but it is the correct size.
And some shop wants to use a distribution block which I see it should be ok but I’m no pro at this kind of stuff that’s why I’m asking you guys.
yeah u use fused dist block for power wire and a non fused dist block for the ground or make a new ground for 2nd amp but lets say your power wire is 10ga thats not big enough for 2 amps is y i asked (unless they both like 200rms amps) also u have to know wire size to order the dist blocks and u have to use 2 short wires 1/2 the size of wire from batt to split off to each amp.. so u need to know wire size and amps u run matter as far as if wire u have is big enough to power both amps..
https://www.ebay.com/itm/381842959941
These are made by Stinger and I use these on installs,and have never had any issues with them or any Stinger product ever.Its all I use.I placed one in a neighbors truck 3 years ago and still looks and performs. If the gauge you are using is smaller than 4ga for a pair of amps of needing 2x25 amped fuses, Id recommend upgrading to a min of 4ga supply wiring and do the Big 3 in 4ga MIN.
All came out great I used a four channel JBL amp and some good rca wires I installed some 6X9 Cerwin Vega old stock but new speakers and up front I’m running some MA Audio 4X6 speakers on my GMC 1993 Ext/Cab truck and for my bass I’m running a 12” Kicker speaker with a Fosgate old school amp and my sound system sounds great I’m mean the best sounding stereo sound I have ever had oh my HU I’m running a Alpine stereo that has three sets of RCA jacks and a extra set to connect my phone I’m one happy camper.
6x9 Rear Speaker Install - GM Truck Central This is where I got the idea and it works guys.
Nice setup
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
915
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
233
gmctrucks
gmctrucks
Houston, Texas
Louisiana_CRX
    May 16, 2024
    May 16, 2024
