sub ohm question
  • 2
unrated
sorry guys dumb noob question, i have 2 dual 4 ohm subs, what would happen if i i ran 1 dual 4ohm sub and wired it to a 2ohm load, then the terminals outside the box jump over to the other terminals and wired it as a 2ohm load, would the amp read that as a 1ohm load , the reason is, im running 1600w@1ohm and my amp is gettin really hot at dual 4 ohm in a 1ohm load
second question is an amp question, some1 said running subs at 4ohms sounds better, i want to get a new amp what would be better
USING THIS AS AN EXAMPLE
A)1000w@4ohms
or
B)1000w@1ohm
whats a better ohm for an amp to run at
Thx
It depends on how you wire it.
If you wire each sub as a 2 ohm load then wire them in a series they'll look like a 1 ohm load to the amp.
If you wire each sub as a 2 ohm load then wire them in parallel, they'll look like a 4 ohm load.
Or I might have that backwards...
If your amp goes 1 ohm stable it will put out more power efficiently is the main difference between that and a 4 ohm load.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Sure we need to grow up, ok. I gave you the exact answer then you blew up on me saying I was wrong. Time for self reflection bud. Cant take...
20
241
unrated
unrated
Vancouver Island, BC
Subz
    May 16, 2024
    May 16, 2024
