sub ohm question
unrated
sorry guys dumb noob question, i have 2 dual 4 ohm subs, what would happen if i i ran 1 dual 4ohm sub and wired it to a 2ohm load, then the terminals outside the box jump over to the other terminals and wired it as a 2ohm load, would the amp read that as a 1ohm load , the reason is, im running 1600w@1ohm and my amp is gettin really hot at dual 4 ohm in a 1ohm load
second question is an amp question, some1 said running subs at 4ohms sounds better, i want to get a new amp what would be better
USING THIS AS AN EXAMPLE
A)1000w@4ohms
or
B)1000w@1ohm
whats a better ohm for an amp to run at
Thx
It depends on how you wire it.
If you wire each sub as a 2 ohm load then wire them in a series they'll look like a 1 ohm load to the amp.
If you wire each sub as a 2 ohm load then wire them in parallel, they'll look like a 4 ohm load.
Or I might have that backwards...
If your amp goes 1 ohm stable it will put out more power efficiently is the main difference between that and a 4 ohm load.
unrated
unrated
Vancouver Island, BC
Subz
