Sub guidance
bilboaudio
CarAudio.com Recruit
I am looking at getting one of these but wondering which would be best all round, but for mainly listening to electronic dance music and classical.
ESX QXB8A
https://www.esxaudio.de/english/qxb8a.html
or
Rockford Fosgate p300-12.
I heard some bad things re the RF subwoofer in the box not being that good whereas the ESX seems to have quality components but obviously its only inch.
What do yee reckon?
ESX QXB8A
or
What do yee reckon?
Make sure to consider the acoustic characteristics you desire. If you're looking for a deep bass response and good clarity in both genres, that may affect your choice.
01001111 01100110 00100000 01110100 01101000 01100101 00100000 01110100 01110111 01101111 00100000 01101100 01101001 01110011 01110100 01100101 01100100 00101100 00100000 01110111 01101000 01101001 01100011 01101000 00100000 01110111 01101001 01101100 01101100 00100000 01100111 01101111 00100000 01100100 01100101 01100101 01110000 01100101 01110010 00100000 01100001 01101110 01100100 00100000 01101100 01101111 01110101 01100100 01100101 01110010 00111111
The 12 has over twice the cone area of 8. It should easily be much louder and play lower than the 8. And even if you aren’t looking for huge volume, that is an advantage.
:) Thanks for the replies. Yes I care and am grateful for the input!
Has anyone any thoughts on the powered sub Rockford Fosgate p300-12 specifically? Most reviews do seem to be good. I can get for about the same price: Pioneer 12" TS-A300D4 & GM-D8701 Amplifier box
For Single 12" Subwoofer
Sealed Enclosure
1.25cu.ft 3/4" MDF box
Dimensions: 56cm (W) x 35cm (H) x 31cm (Bottom Depth) x 22cm (Top Depth)
Carpeted in black.
Or is that sub considered low end in terms of audio quality?
I'd lean Rockford over Pioneer simply by name, but there are other factors to consider.
What's the power in each setup? What's the sensitivity of each driver?
Detailed specs on the RF are scarce :/ but its a 300 rms amp
High temp 2" voice coil w/ spun-laced Nomex insulating re-inforcement collar
Frequency response: 35-150 Hz
Pioneer amp RMS 300 W x 1 (4 Ω), 500 W x 1 (2 Ω), 800 W x 1 (1 Ω)
Sub:
Frequency response:
20 Hz - 2300 Hz
Impedance:
4 Ω Dual Voice Coil (DVC)
Nominal input power:
500 W
Sensitivity:
77 dB
Resonance Frequency25 Hz
Xmax10.1 mm
Magnet Weight1,700 g
Voice Coil Diameter55 mm
Recommended Enclosure35.4 liters
Sealed Enclosure
Carpeted in black.
A friend has that same Fosgate. It sounds pretty good but I think it will pale in comparison to a 12 in a bigger box and more powerful amplifier. Those are specific for when space is an issue and you must bass to keep your sanity.
I have never heard that Pioneer so watch videos of it before purchasing. For a little more than that price point I would opt for something from Skar, American Bass, or CT Sounds.
bilboaudio
bilboaudio
Isle of Man
BP1Fanatic
BP1Fanatic
