sub connection thru box
  • 6
i'll just go with the stainless bolts , for easy box removal from my blazer . thanks
Yuppers....easy disconnect
I've used all 3 methods. I will warn you, if you use bolts make sure you secure them very tightly. They will get dangerously hot if they loosen up.
To an extent. I could hear the wood crunching while tightening mine so I stopped. Might add to use loc-tite....if it's ideal in this situation.
Yes on both of these. Splicing means connecting one wire to another. So one wire to the positive and one to the negative wires or terminals of...
894
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Sensitivity is usually measured 1watt 1 meter. I'd go by that. Higher the better on subs too. Less power to get louder. Every 3 DB gain is like...
84
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
229
235
02Blazer
02Blazer
San Diego, Ca
Boomin_tahoe
slater
    May 2, 2024
slater
    May 2, 2024
