Sub Configuration?
kuijo
Ok i just bought an AUDIOBAHN A8002T and the specs are
200W x 2 RMS @ 4 Ohms stereo
400W x 2 RMS @ 2 Ohms stereo
800W x 1 RMS @ 4 ohms mono
I want to get some hard punch out of them. So which sub configuration should I be looking at:
4 ohm DVC with 400wRMS (wired for 2 ohms)
2 ohm SVC with 400wRMS
4 ohm SVC with 200wRMS
2 ohm DVC with 400wRMS(wired for 4 ohms)
Or should i be looking at a diffrent combination and wattage?
Right now i've got 2 10" MTX Roadthunders that are 200rms at 4 ohms(SVC) and i feel like i'm going to break them and they're a bit sloppy. Is this because they are lower end subs?
ANy recomended subs that put out a nice crisp punch?
I"m putting the subs in a probox for my standard cab f150
Thanks for your time
~Mike
I'd get 2 dual 4 ohm subs and wire them in series/parallel to get 800X1.
but if you can only get 400 watts total, don't worry... I'm only running 420 watts RMS for my subs and they get loud enough for a decent daily system.
Not take you breath away loud, but I can feel my hair vibrate.
Thanks for the correction.
kuijo
kuijo
TX
bonesninja
