Sub can't hit lows?
AJM511
Chill as a Cucumber
i have an MB Quart rwe-302 12 inch sub 500 watts rms, with a kenwood excelon x20, which gives 520 watts. The sub can't play the low notes, like the ones in the song "bass, i love you". Instead, a popping/clicking noise comes across the component speakers. I have the LPF set to about 75 HZ. Also my box is a 50 dollar truck box from groundshaker, which could be part of the problem.
High pass(hpf) your component speakers...they shouldn't even come close to playing those really low notes in Bass I Love You. 80hz is normal in order to keep unwanted bass coming from your door speakers.
As far as your sub not being able to play the low notes: it takes a good amount of cone area and power to make 10-20hz sound legit. A single 12"er isn't going to make the ~10hz and ~20hz notes in that song wang, never going to happen.
There's practically a million reasons this could be happening. Poor gain settings. Low system voltage. Improper speaker wiring. Bad grounds. Enclosure design. Etc.
problem is probably since this dude is running factory speakers , he probably has a factory deck which more than likely doesnt have a frequency response wide enough to reproduce those notes
Even most cheap CD players have a usable freq response of 20hz-20khz. That's pretty standard. But weak signal strength could lead to one of the gain setting problems I referred to earlier.
AJM511
Chill as a Cucumber
AJM511
groveland, ca
audioholic
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
