sub amp advice?
  • 2
TadCat
Hello all, this is my first post on this forum. I just signed up and wanted to get some peoples' input on a few amps. I am looking to buy a new amp to power my JBL w15gti mkii (800 watts rms, 5k max.) I already know I'm going to get a Zapco z-150.2 for the components, but since I'll be replacing a 5 channel amp (right now I have a jl mhd 900/5) I'll need to replce the sub amp, I wouldn't mind it being a little louder, but I'm really worried more about sq, so which of these amps would be better for SQ? Durability? Value? Any other suggestions would be great too, thanks.
Zapco z-2KD
Sundown audio saz-1200D
Jl audio 600/1v3
Jbl gto14001
P.s. - I know the Zapco amp would probably be the best by far, but if I can avoid spending $900 that would be great.
I'm trying to keep this whole upgrade's cost under 400 dollars, I'm assuming the amp I have now will sell for at least 700 dollars, and I'll be getting the front amp for about 400, which leaves me looking at 700 dollars for the sub amp. I'm willing to spend the extra to get the Zapco if it really is a substantial improvement over the others. Are the others really that bad for SQ? And how do the Zapco I force or the Zapco dc series compare to the z2k? Thanks for the input, by the way
There not bad. But not really in the same class as a sq amp. If you want an sq amp. The arc audio Zeff design amps. Zed helix audison amps. The zapco amps are decent amps. But I hear the quality isn't what it used to be also the ground zero reference amps are pretty sweet FYI Basically there are many options. But your budget may limit you from a few of them
Yeah I know of some of them, audison amps are really just out of my price range, and the class g/h amps from arc can't accept the preamp voltage from my head unit (pioneer deh 80 pts) but I'll look in to the zed and helix amps if you think they can outperform Zapco. I did just find a Zapco dc1100.1 for 400 bucks on amazon, though.
Yea don't buy from a non authorized dealer. Your asking for trouble with these brands if you do. Arcs new xdi line is Zeff designed tho with 90% and over efficiency and at a pretty good price point for them
The newer xdi amps should be fine I'll have the new price sheet on a day or two. The amps shod be available by the end of feb I have access to zapco and helix to
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
543
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
661
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
657
TadCat
TadCat
San Antonio, TX
TadCat
    May 18, 2024
    May 18, 2024
