Stupid problem. Help hooking up sub amp to factory stereo.
dtbrown
Ok, weird problem. I've got a two channel 85w line output converter (soundgate) and hooked it up to factory rear sub outpupt and it won't work. I have to use sub output from factory amp due to interior speakers are x-over. Now this is the second different brand line output converter that we've tried with no output signal.
Now the kicker is I took some rca's and spliced them into the into the single channel of the sub output that I was using and it works. But I know that the line output converter is supposed to be better. Any suggestions or is the way I'm doing it fine?
Vehicle is 08 Lexus IS350
if it works and every thing sounds fine then i guess its okay....just make
sure your sub(s) is picking up a clean signal....no noise or anything
dtbrown
dtbrown
Chicago, il
dtbrown
BP1Fanatic
BP1Fanatic
