Stumped by comp noise/hiss
amedeuce
:crap:
Ok, I've searched and searched and tried everything I could think of....
I have this hiss noise from comps with engine off and on. No alt whine.
I have disconnected power from battery and rca's from the sub amp and head unit(tantrum) just to rule it out. - same noise.
JBL px300.4 turned gains to zero, disconnected rca's from head unit and amp - same noise.
Alpine 9833 head unit grounded to battery - same noise.
Tried different head unit alpine 7892 - same noise.
RCA's are routed on different side of vehicle but do come in close vicintiy at amps of course.
ONLY thing done recently is run new KNU flexible 0 gauge to (newly purchaced)tantrum and new KNU 4 gauge flexible to JBL.
I did have to piece togther the 4 gauge in a distro block to reach cause I didn't order enough - it is pieced together with some kicker 4 gauge.
Could the speaker wires be picking up the noise through the power wire? But the noise comes from both sides and speaker wire is routed on either side of vehicle.
forgot to post about grounds, had everything in word document.
Grounds for amps are good grounds - hell the grounds are grounded to try to solve this problem. Where my amp grounds are grounded, the back of the screw goes below the vehicle which I attached a ground wire to and grounded that to the actuall steel frame to make a chassis to frame ground
I was thinking it could be the power wire, but how could it be? I disconnected the 0 gauge at the battery. Same noise.
Can't be power wire and rca problem, rca's are disconnected.
I guess that leaves speaker wire and grounds.
But I know the grounds have to be good and I didn't have the problem before with same grounds and the speaker wire is the same.
Could it be that 4 gauge power wire pieced togther?
This is like my own little noise issue journal where I talk to myself about my problems....
Dear diary....//content.invisioncic.com/y282845/emoticons/cuddle.gif.bd1b29c179c0482f8313dbd790b74c94.gif
Disconnect the RCA's connected to the amp's inputs and plug in muting plugs.
If you still have a noise, then the noise is coming from the amp or after the amp (i.e. passive's picking up noise from somewhere, etc).
I haven't tried the muting plugs yet going to make some now, but the noise is there even with all rca's disconnected. Still need to try muting plugs?
Reminds me.... i need to make some mutein plugs... thanks...
Ok to make muting plugs (I've seen the video) can I just take a set of RCA's cut the ends off and strip back both wires inside and twist those together and that will be muting plugs?
No passive crossovers, I'm active.
amedeuce
:crap:
amedeuce
CA
amedeuce
