Strange thing with System
cappy72
NY
I read about amps going into protect mode due to the low signal of the remote wire when you have a couple of components hooked up.
Well I am starting to think that this is true... today I got a new d5 1200.1 amp(cause I thought the other one was having technical problems) and I hooked it up, it was connected to my active crossover. Well my amp starting going into protect mode for some odd reason. so I started looking because I thought it was odd to have 2 amps going into protect mode.
I started adjusting the gains and boom protect again... hmmm
so I decided to disconnect the xover and ran the Rca's directly to the 2 amps. hmmm... now the subs are stronger than before>??? this is odd
any explanations?
my firebird did that all i did was use a relay for the remote and it took care of the issue. was funny my old pioneer turned everything on a ok but the short lived alpine couldnt lol
good link... thanks
did you throw a fuse between the remote inputs and the relay output? if so what size did you use? I am thinking about a 5 amp fuse but I dont know if that is too little
cappy72
cappy72
NY
audiolife
