mhsnolie08
I just purchased a new Alpine SWR 1243D and a new custom built alpine vented enclosure, at the bottom is the specifications for the enclosure. I had previously owned an Alpine SWR 1243D subwoofer that was in its own vented enclosure and it worked fine with the same amplifier. I took my old alpine and put it with the new one that I have purchased. The issue is that only the new one that I have is making a strange rattling sound when the amp is turned up. I have a Boss Audio Nx1800.1 1800W Mono Block Amplifier. I have been doing some research about this issue with the noise the subwoofer is making and I'm not real sure of the noise that I am experiencing. Two common terms I have seen are bottoming out and clipping. I just don't see how either of these could be the issue as it's only applying to one subwoofer and not both. I have an 08 Honda Civic with the factory head unit, I just used a LOC to connect the amp. I'm hoping it's a simple setup and not a messed up speaker because I don't want to have to return the sub. Below I have attached some additional pictures to show wiring setup and the setup of my system.
Dimensions:35"W x 14.75"H x 15.25"D
Cut out diameter:11 1/16"
Mounting depth:13"
Cubic Air Space:1.65 Per chamber or woofer
Tuned at 40HZ
Holds two 12" woofers
Constructed in premium 3/4" MDF
Mounting depth:13"
Tuned at 40HZ
