Stinger Expert series 4 gauge wire
I would probably go with larger. It might handle it fine, but you are pretty well limited to a 120A underhood fuse because of the size of the wire. If you find out that you are blowing that fuse you will have to rewire the main run. Do it right the first time with 2 ga or 1/0 and you won't have to worry about it.
if i was to go with the 4 gauge and got a distributor block should i go with a T (1- 4 gauge input/2 4 gauge output) or a T (1- 0 gauge input/2 4 gauge output)
or
just run 2 4 gauge wires using 2 seperate fuse holders and a battery terminal
2 boss c1200 amps
Amplifier Type: Mono
RMS Power: 400W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.01 %
RMS Power: 600W x 1 @ 2 Ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 102 dB
Fuse Rating: n/a
trigga_b
trigga_b
chicago
trigga_b
