Starting to lift....
nissanrider06
VooDoo
i've been lifting every other day at home just like arms and abs and stuff, but am about to start staying after school and lifting regularly and was wondering how often i should be lifting? mon, wed, fri??? whats happens if i lift daily? and is creatine or any of that other stuff work???
if you lift daily you dont leave your muscles any time to recover, well that is if you lift the same muscle groups daily. if you do upper body m,w,f and lower t,th then you will have no problem. if you want to get big do fewer reps with more weight. and yes creatine works
Search, there are countless threads on exercise... Just be sure to aviod any of FatRyans advice on this matter.
But a rule of thumb is to work out every other day to give your body a day of rest in order to 'rebuild' the muscle tissue that was previously torn during your work out (which would result in the build up of more muscle.) If you work out lightly every day (maybe 30 minutes or so) then you should be fine doing it everyday, just some people find it hard to do because of their schedule and excessive exhaustion...
And I have heard that creatine can help, but it deffinitly wont hurt you so why not try it?
Its best to give atleast 1 day rests in between workouts of the same muscle.
You could work out everyday and do different parts of your body like legs on monday, cardio on tuesday, arms on wednesday, ect. and then give yourself a break on the weekend or something.
Also keep in mind that working out is only half the battle in getting and staying tone and in shape. The other half is all nutrition but i'm sure you have heard of this.
About the creatine, I have never used it but I don't think its really necessary unless you want to get big really quick. I would rather use protein shakes.
As to the nutrition aspect, I have found that you do not need to alter your diet if you are simply trying to 'bulk' up, but if you wish to define and lose a large portion of your body fat then you should definitely rethink what you eat.
Everyone who says you need to alternate between upper body and lower body is wrong...
Just dont work the same muscle group two days in a row...
For example...
My routine:
Monday: Legs
Tuesday: Chest
Wednesday: Shoulders/Traps/Abs
Thursday: Back
Friday: Arms
*EDIT*
To those of you asking about creatine, honestly just search google. There has been TONS of research. Basically, it makes your muscles absorb more water which increases the size of the fibers and thus muscle. This gives you an ability to lift a little more weight, especially the last few reps. This, in the end, helps increase strength even after you stop using creatine...
Protein powder would probably be the easiest/safest route for those who are too lazy to do research or do anything the right way...
Pretty good advice from everyone. Lets talk about your age, background and health problems first though.
In general, like everyone said you need to rest your body so it can recover. You will find some great results by doing so. ACSM says that 30 mins of cardiovascular exercise daily will help prevent heart disease and reduce your chance of a heart attack by 80%. They also say that an exercise rutine of 2 sets of 12 reps with a weight that is challenging but not overbearing for the last few reps is all you need to maintain a healthy body.
On the other hand, if you want to build lean muscle you will need heavier weight. Even to the point of failure.
Creatine does work. It stores more water in the muscle cell. By doing so, it creates a better enviornment for growth. Protien shakes are not at all the same thing.
D
nissanrider06
VooDoo
nissanrider06
Eagan, MN
yz_gt69
BP1Fanatic
BP1Fanatic
