started my center channel build
silvercookie
WRX
all constructed out or 3/4 mdf
this was with some wood i had layin around so i just drew some shit up real quick.
didnt measure out the cube it would be cause i was bored
but it is around 9" or so high
about 7 "wide
and about 2 feet long
im putting a pair of rockford fosgate t1 5 1/2" coaxes in it.
if they sound good im just gonna leave it.
if not then i will throw in the diamond audio d651i midbasses in as well.
pics tommorrow.
i didnt take pics of all the steps
only pic i got is the box put together minus the side panels.
and i just have to cut out the hole.
I don't recommend using a pair. Tweeters will have comb filtering issues when listening off axis (cancellation of certain frequencies). If you can just use one coax or maybe even find a way to stack them vertically, it would be better. Or, disable one of the tweeters and add resistors to pad the woofer output. Well, maybe I am over reacting a bit, as some people aren't bothered by comb filtering issues but sometimes it can really be bad even for a casual listener.
It is unfortunate that the horizontal layout has become popularized as the norm for a center channel speaker because ideally the center channel should be as similar as possible to the left and right speakers.
ya.
right now i just want somthing.
can be anythng.
dont really care, but i can always swap out speakers.
as i made each panel 8" tall or wide depending on how you look at it so i can upgrade up to 7" in th future if needed.
One tweeter and two mids should work. Cross over as low as possible. If you can get a tweeter that will cross at around 1500-2000hz with a 4th order slope then comb filtering should be greatly minimized. You still want to place the mids as close to each other as possible (center to center spacing).
english:confused:
i got the crossover part.
but the rest ii might as well be a chinese woman driving a 18 wheeler.
silvercookie
WRX
silvercookie
Queens, NY
silvercookie
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
