SPG555 2Ohm or 4Ohm
gizmo206
23
NL
Can some/one tell me which sub will be better The 2Ohm or the 4Ohm.
Thanks.
General Specifications
Model: SPG555-4 SPG555-2
Nominal SD: 555cm2 555cm2
RMS Power Handling: 1000w 1000w
Impedance: 4Ù 2Ù
Frequency Response (±3dB in car): 20-350Hz 20-350Hz
Weight: 26 Lbs 26 Lbs
SPG555 Thiele-Small Parameters
Fs (Hz): 31.90 29.68
Re (Ohms): 3.15 1.68
Qms: 11.66 11.70
Qes: 0.86 0.67
Qts: 0.80 0.63
Vas (Liters): 39.77 44.40
Mms (Grams): 276.7 286.20
Cms (ìM/Newton): 89.9 99.9
Xmax (Mm): 22 22
Xmech (Mm): 49 49
Sd (CM 2): 555 555
Bl (Tesla-M): 14.27 11.58
SPL Eff (dB @ 1w/1m): 83.6 84.2
SPL Sen (dB @ 2.83v): 87.7 91.0
that is an awesome driver! go with the wiring config that best suit's your amp at full power! you can alway's change it also, just by the new coil
Stll need to buy an amp for the sub. So should I go for the 2 or 4 Ohm?
It won't matter if it is 2 or 4Ohms as far as how they sound. Just get the config that is best for the amp you are going to use with it.
Wanted to buy the jl 1000/1
it's Rated Power: 1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
So 2 or 4 Ohm wo'nt make a difference.
Which sub should I take?
Thnx
gizmo206
gizmo206
NL
dipitydoo
