Speakers pop when head unit or car is shut off.
You don't have enough delay time from your HU in regards to supplying power. This might help fixing that
Product Description
Combines multiple features into one SKU covering more than 16 different applications including low voltage trigger, Alpine video bypass, latching output, double pulse output, pulse extender, linear actuator controller, channel splitter and more!
Product Features
Low voltage trigger
Alpine video bypass
Latching outputs
Double pulse output
Pulse extender
Linear actuator controller
Door lock pulse generator
Channel splitter
3 in 1 timer outputs
Pulses to timed output
Turn on pop delay
Delayed amp turn off
if the speakers are powered by the head unit directly then the problem is in the head unit. disconnect the RCA's and see if the problem persists. if it persists, replace the head unit. if it goes away then you have a grounding issue with your RCA's and they should be replaced (or tested for continuity of both shields).
i've seen head units make noise on on/off when RCA's had disconnected shields - but usually only through other RCA outputs.
the internal amp is a single unit that does everything - it too can fail, or other components associated with it can fail (caps or resistors).
Didn't help. Hooked to good ground. New speakers. Nothing
Sorry to hear the PAC TR7 didn't help at all. Did they ship it overnight or were you able to find one locally? You mentioned looking for a cheaper solution and went ahead buying new speakers instead, too bad that didn't work either.
I've been there's there's a speaker or remote wire shorting out
I'll get back there and try it again.
It shouldn't be my head unit. When this was professionally installed I had no problems. I rewired my door speakers to my head unit and this started
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
981
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
294
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
431
LongThrow
My Kickers be swaggin'
LongThrow
Springfield, MO
LongThrow
maylar
    Jun 2, 2024
    Jun 1, 2024
