speakers not working only sub is????
the pyramid amp would work, but you would have to run wire throughout your car for it (speakers to amp). hence you had your stuff installed previously i doubt you wanna run a amp yourself. also do you have front and rear outputs on your deck? if not i dunno if you can use it, unless some type of converter.
like everyone is saying check the wiring, check every speaker to see if its connected. my wire has fallen off a speaker before due to a bumpy rd. they could of pulled it out when they were running power wire.
man im tellin u, the same thing happened to me. i have my remote wired to the blue with stripe and the blue wire, cause if i just had the blue or blue with white only one would play, so its worth a try??
zeldagadian
zeldagadian
Canada, ON
DbRufus1234
BP1Fanatic
BP1Fanatic
