One more big 3 question
Colt9699
Rockstar
Ok I went out and got some more 4 ga wire to do my big 3 upgrade and I was gonna buy ring terminals(lugs) and not sure of the size I need.
I know they need to be 4ga but I am interested in the hole size of the ring?
1/4" or 3/8" holes?
I was thinking the alt + is gonna need a 1/4 and the battery will need a 3/8 and i can use 3/8 on both ends of - to chassis ground and most likely 1/4 at the - on the alt and a 3/8 for attaching to engine block.
does this sound correct to you all?
sorry I'm just another noob who's lights dim just a bit on big bass notes!
Also will a 100 amp fuse be sufficent for 4 ga wire?
Ok I have a viper d300.1 amp and the owners manual says the dual + and - subout terminals of the d300.1 are paralleled internally and the combined load impedance should be taken into consideration when connecting multiple subwoofers
What exactly does this mean?
Says amp is a 1 channel cladd mono sub amp .
So why do I have what seems to be 2 channels for a 1 channel amp?
Also is there any other ways I could make the sub connections?
I have 2 subs connected with the right side + going to the right side + on the amp and the right - going to the right - on the amp .
the left side + is conected to the + on the amp and the - is connected to the - on the amp.
Thanks in advance.
if you can afford it.. get 1/0awg. Use all of the same crimp rings, you dont need to split them up. If its too big of a hole.. get a washer. If it's not big enough, drill it out a bit. 4awg is hardly going to help at all. go big or go home. Use a 250-350 fuse for 1/0awg and a 100-150 for 4awg.
Colt9699
Rockstar
Colt9699
Erie Pa
Colt9699
BP1Fanatic
BP1Fanatic
