SPEAKERS AUDIO CUT OUT WHEN SCREWED TO DOOR
Teamsizzle55
I recently purchased some kicker speaker and a jvc stereo system, however whenever I go to screw down the rear speaker on my car door it stops the audio from working for all the speakers but when I remove the screws and just have the speaker sitting in the door unbolted it works fine. Any tips ?
As stated above, it appears that the speaker is grounding out when it touches the metal speaker cutout in the door. Check the wiring at your terminals to make sure that none are touching the frame of the speaker or cutout. If the problem persists, try isolating the speaker from the metal door frame, with some type of foam or gasket material. Use plastic wall anchors to keep the speaker mounting screws from directly touching the metal in your door. Good luck and let us know who solved the problem.
Update: I’m a dumbass! The speaker bracket that “Crutchfield” sent me didn’t come with directions so installed the speaker in the bracket backwards causing the magnet on the speaker to be too close which made it touch metal
I found the thread and responded to it sir! Consider these SOLD!! Please Check your Payment transaction. I thank you
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
Also if you did decide to get another amp the output rca on the amp can be adjusted with the internal dsp
Teamsizzle55
Teamsizzle55
Maryland
Teamsizzle55
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
