Not Again!!!!!!
fatryan
Banned
WTF is wrong now? I was driving around 2day doing some freakin shopping and i noticed my d@mn front-right comp started cutting out! WTF!?!? Theres no possible way that i have gotten 3, yes 3, bad RCAs. Thats friggin impossible! Its gotta be something else. Some1 please tell me how to check my HU pre-outs and amp RCA-ins for problems. TIA
well, b4 when this happened, i switched around the rca's to see if it would make the other comps cut out. and it did, so its not the speaker wire. its something between the HU and RCA ins on amp.
No, not your head unit but your installation yes. RCA's are cables just like any other. Only difference is they are dedicated to a type certain signal.
If you want to check the pre-outs, get a voltmeter and check em. What are you thinking is wrong with it though? Just a bad pre-out that is operational sometimes???
thats what i would think, BUT last time this happened, i switched the rcas in the back of the HU too and it still did it on other speakers. which only points to bad RCA's. am i right here?
Wiggle the RCA inputs on the amp and see if it cuts out.
A bump to the RCA inputs can lift them from the circuit board and cause an intermittent connection, check the outputs on the back of the HU as well.
If an RCA input has come loose from the circuit board you will need to resolder it.
last 2 times, if i wiggled the rca wires at the amp, it would cut out. this time, i cant seem to get it to cut out by doing that. i tried wiggling them, then they began to function properly. and as much as i wiggled them, i couldnt get them to cut out again. but this morning when i went for a drive, the speaker cut out again. im so confused about this.
sound like the input rca's are bad on ur amp. take the rca's that are runnin ur front and plug then into ur kicker 1200.1 and see if makes the subs cut out.THen if that is not the problem take the rca out and hook them up to someing else like ur home stereo. And see if they cut out in ur home setup.
the process of elimantion really helps here.
why is every post that make a journey in angry yelling and cursing?
Everything you do is.......... WTF? those god **** ****ers.!!! WTF? ****! I'm so ****ing mad. WTF. **** you and **** you. WTF? WTF? This sucks! Why is that guy such a ****er! **** this. That ****er. WTF. ****. Balls! SHIT.
chill out a little
???? ^^^ your ghey, hahaha, is that better,
dude the guy has had probs with 3 RCAs , id be a little pissed too, and looking back he didnt really cuss that much //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
yeah process of elimination should be the key here, but three RCA is ungodly odds
I like FatRyan too, I have always been fascinated with Tourettes.
Tourette syndrome (TS) is an inherited, neurological disorder characterized by repeated involuntary movements and uncontrollable vocal (phonic) sounds called tics. In a few cases, such tics can include inappropriate words and phrases.
The disorder is named for Dr. Georges Gilles de la Tourette, the pioneering French neurologist who first described an 86-year-old French noblewoman with the condition in 1885.
The symptoms of TS generally appear before the individual is 18 years old. TS can affect people of all ethnic groups; males are affected 3 to 4 times more often than females. It is estimated that 100,000 Americans have full-blown TS, and that perhaps as many as 1 in 200 show a partial expression of the disorder, such as chronic multiple tics or transient childhood tics.
The natural course of TS varies from patient to patient. Although TS symptoms range from very mild to quite severe, the majority of cases fall in the mild category.
Might he fall into quite severe???
Peace outside round eye.
T
fatryan
Banned
fatryan
Southampton, Pa
SPL140.2
