Speaker wire thickness
Good wires will increase the signal flow and also allow for more power..If you are running a SQ system or a high power system you will notice but not a big difference. I personally use 12-14AWG to allow for both and room for growth.
Mike
No matter what calibur sound system you have bigger gauge speaker cables will make a very noticeable difference. If you are running like 20 gauge for your subs and you switch to 12 gauge(recommended for any sub) you will notice much better bass. The same holds true for home stereo. Use a beefier gauge wire on your home stereo speakers and notice how your bass response goes up. Low frequencies(bass) are the hardest to reproduce. So when you increase your signal flow with bigger gauge wire that is the biggest improvement you will notice.
Larry
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
901
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
C-Dawg
C-Dawg
San Diego, ca
Larrydehp920r
    May 16, 2024
    May 16, 2024
