Speaker Wire Melting
You need to use a good 12ga/10ga of wiring,nothing CHEAP..Id use 10ga,and you will need to rewire all your subs with the same wire throughout back to the amplifier.And change that connection as well/possibly all of them,as they are cheap possibly,and cannot withstand /disipate heat very well.
and this is why I don't use terminals to make connections. changing metal between signals as well as too small a gauge of wire contributed to the melting of that wire.
What do you use? How is 12 gauge too small? If I remember correctly it was a pain in the *** to connect to everything because it was thicker..So I should us 10 gauge now?
Thanks, could you recommend a better connection?
wire directly to sub than wire to wire. i don't use terminal cups or connections ever. I use 12 gauge for anything under 800 watts RMS, anything above that gets 10 gauge and goes directly to the amp if possible.
So if I where to wire directly to the amp now, how could I do it? Would I just drill a hole in the terminal somewhere and run it through? Any issues with sound leaks or anything like that?
KJThaDon
KJThaDon
Westland. Michigan
Slo_Ride
