Speaker Level Inputs
psy4s
http://1stmob.com/
I just purchased a New Infinity KAPPA FOUR 125w per channel amp. It takes the Line Level as well as low level Inputs. Would there be any advantage to using a Line Level converter and running low voltage in instead of using the Speaker Level inputs. My Radio does not have RCA's and it runs a true 45w per channel RMS. If it would be better to use a Line out converter, which will work best with 45w? I have seen some that were not rated as that high.
I really need your help here, Thanks.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
not really. just hook speaker level wires to the amp. pretty much the same thing, except sometimes you get better function from the amp, and the potential for noise on a loc, imo
psy4s
http://1stmob.com/
psy4s
Greenwood, IN
akheathen
