Why is that? I would've said tap the LOC on the rear speaker wires from the head unit before the stock amp, so as to get a signal before any processing has been done.after. on the front mid wires
that works too. i tap the mids because they are normally fullrange and the amp is normally in the trunkWhy is that? I would've said tap the LOC on the rear speaker wires from the head unit before the stock amp, so as to get a signal before any processing has been done.
Ahh ok, I see what you're saying then.that works too. i tap the mids because they are normally fullrange and the amp is normally in the trunk
