speaker install question.
It shouldn't really do anything bad to the speaker.. itll scuff the magnet maybe, and maybe mess your window up.. but shouldn't affect the speaker quality wise.. but i might be wrong..
Andrew
If you've got a little extra room in front of your door panel you can make an mdf ring to bring it out a little.
- This is the safest bet.
But as long as it does not touch the black ring magnet that encircles the magnet area, you will be okay. You never want anything to touch that, they are fragile like glass and pieces can shatter.
If it's just touching the bottom of the magnet, and you can't or won't use a spacer, I'd treat or paint the bottom of the speaker with some kind of damping material.
I've spaced it out to my max.
These memphis' have a rubber ring around the magnet for protection.
It seemed like its only rubbing on the very back of the magnet.
I was just worried that the magnatized metal would cuase interference or something.
- Don't be fooled, it might not be enough protection if it hits something solid.
- not a problem as long as you get some damping stuff on the back.
ledzeppac
ledzeppac
orange county, ca
Gary S
