What Ohm Load Will This speaker Combo Produce?
bones justice
i jus bought some 18 sound 6.5" midbass speakers and a pair of beyma bullet tweeters.
the tweeters are 4ohm
the midbass speakers are 8 ohm
can i run a speaker and tweeter to a channel on my rockford punch 450.4
if so what ohm load will that produce 4ohm , 2ohm?
also can i run the speakers and tweeters together or should i buy a passive crossover to have it like components.
HELP PLZ.......
18sound takes lots of power...so i guess thats the reason why he may want to bridge.....if u bridging them bones justice....run some condensers on the bullets so that the amp wont read it as a load.....
To do it right, you need to have a passive crossover splitting the signals to the tweeter and mid. If not you'll fry your tweeter.
Oh, and for those saying an 8 ohm speaker with a 4 ohm speaker ran in parallel is 6 ohms... ummmmm, no....
It's 2.67 ohms.
It's 2.67 ohms.
x2
you need a passive cross over.
but you can run each set on 2 chanell of your amp.
or you can use your mid's on bridge mode.
and use the tweeters on 2 chanel seperatly.
bones justice
bones justice
Los Angeles
paymanonline
