Speaker Distortion after new installation
Dragon56
Hi Folks,
I just installed a new Pioneer head unit Model DEH- S6000BS in my Motorhome. The existing speakers
are mounted front and rear of the cabin. The original cassette player had only three pairs of speaker wires. After tracing out all of the wires I found that each speaker has one separate wire, but each side ( left and right pair ) has a common wire. The wiring diagram on the new deck shows each speaker with two separate wires to each speaker. Once I connected the speakers using only the wires I had I found that I have major distortion at volumes over 20. All of the speakers sound the same and none are worse or better than the others. Is it possible that I will have to run a separate pair dedicated to each speaker?
Any Advice?
Thanks
Dragon56
Yes you will need to wire each new speaker to each connection on the new radio by manual specs
You should have one pos/+ wire and one negative/- wire for each channel to each speaker for the new radio and new speakers
You may have 8 ohm or 2 ohm original speakers as well but properly wire using the diagram as shown in the radio manual and go from there. Its possible you may have blown/or rotted surrounding existing speakers as well
Dragon56
Dragon56
Alberta,Canada
BOOMINGRANDPA
