Speaker baffle problems
klepto
Perveyor of Filth
So i have some rather large speakers with an outside diameter of 7 1/2 (Crystals). I am putting them in the place of the stock 5x7/6x8 holes with 1/2'' MDF baffles. Now after cutting the baffles to fit the speaker and line up with the stock door holes im left with a problem i knew i was going to have.
My door has ridges in it around the 5x7 hole that interfere with the flush mounting of the baffle. Here is a pic in which you can see the ridge.
You can see the ridge in the right hand side...
And here are some pics of me putting the baffle up to the actual door. You can see there are some serious gaps because of the large OD of the speakers and the ridges iin the door.
How would i go about sealing these gaps? Some sort of caulk? Silicone? More dampner? I all ready plan on using non hardning model clay on the finished product but that is no where near strong enough to seal these gaps.
Thanks.
yep.. you live in san jose, go to the michael's at mccarthy ranch.. i just got some this weekend.
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
613
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
491
654
560
klepto
Perveyor of Filth
klepto
San Jose, CA
helotaxi
