Soundqubed vs Hifonics ?
it did 2k on the burst....and thats where it counts right.. at least that what everyone including meade said.... and if its 1200 thats even worst for sq/aq lovers
Burst or dynamic is clipped. Look how the good amps only increase a little on dynamic and the lower amps increase a ton. It shows how fast they go from clean to very dirty.
they simulate more so the music the clipping wouldnt be enough to harm the sub.. but would i rather it not be clipping of course but the end of the day buy what you want.... im going to id run either or they both do what we need them to do and end of the day i think thats all that matters
I think it's pretty simple.. Usually people buying SQ amps have quality gear and people using the Hi-fonics are using gear they can afford. Doubt you're gonna see someone running DD subs and a Hi-fonics...Just sayin...They are good for what they are but lets not get carried away. The people nut hugging em are doing it because they can't afford SQ while SQ people run them because they are superior.
im no nuthugger of either brand, that being said i have owned a brz for around 8 years sold it 2 years ago the thig did rated on music guaranteed and ot is still running strong to this day.... they last for the money spent! 75 dollars might not seem much but it adds up im a **** penny pincher, just my. 02 cents
How do you know it did rated on music? Did you clamp it? What did you have it wired to, .25?
Even the best quality Korean amps don't do rated on music when wired to the rated load.
That is completely wrong. A good friend of mine ran his DD 9515 on a Brutus 2400.1 and it pounded
Get off DJL's nutz //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Exactly lol my buddies been slamming a 95 on a Hifonics for a long *** time .. And I had a Brz slamming my Xcon ... Idc what these idiots say if you wanna spend extra cash to make your peener feel big do it .. But Hifonics aren't bad Amps .. They are awesome for the price .. Almost every bass head started with them .. Only reason people upgrade is for more juice and lower ohm loads
Yea, if they made larger amps people would buy them. The mainstream market only makes amps so big before the prices get retarded
i apologize for making such a bold statement lol, but. im sure you understand what my point was. after box and imp rise wired at .5 ohms it did as close to rated as possible better suited?
doing rated is doing the power its advertised rated power, which is 2400 watts. However even after rise wired to .5 nominal you'll be around 1800-2000 watts on a soft clip. So in hindsight, NO its not doing rated. its doing some decent power for the money but its not doing rated.
well thats what i have planned for my 9518. i dont see why spent the extra cash. that can go towards a battery now
Oh and now soundqubed doesnt list thier amp at 12v anymore. its a full 14.4v
Specifications
Model Q1-2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
THE NEW SPECS
[b
Specifications
Model Q1-2200.2
1 ohm power
1 ohm Power @ 16V
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)][/b]
also i have no idea if this will mean **** about **** buti full tilt my system with the electrical you see on my sig.
i do this always at 13+ voltage idle no rev, cruising there is litterly zero voltage fluxuation under 14v on full tilt.
i'll be damned if a hifonics would let me do that on a stock alt lolol
I'mPoor:(
SoundQubed Is Life.
I'mPoor:(
Gadsden, Alabama
basswiigee2fix
