DjDan101
I know that some amps aren't 1 ohm stable and wiring them that way can make them overheat, but what would happen if you were running it at a low power, say 40-50%, but it was wired at 1 ohm?
Example: An amp puts out 600 watts at 2 ohm, but you need 750. Logic would dictate that it would potentially put out 1200 watts at 1 ohm, but you turned it down really far so that it only does 750. Would the amp still overheat?
This is just a thought I had, and I'm still pretty new to the slightly advanced parts of car audio, so I thought I'd use the thought as a learning experience.
