Soundqubed hds212.. ****
Dang 19 huh
yea those subsonic filters actually HELP widen the passband while limiting output in order to give you MORE lowend and protect the woofer.... i personally think its changes the sound of the alignment similar to a LPF.. not to metion its 4 18s. the mass from all the drivers in a single chamber help with the lowend. regardless jeff's systems looks to be very impressive..
**** i like that flat ****! lol maybe abit smaller and higher tune with more port area?
gonna just shove a 1 cubic feet sealed prefab in there and then throw another one and keep throwing more in and see the changes. Gonna have a meter to measure gains/losses
More port area causes the subs to act like its IB and lose all output.
ouch. that might change when you lower the vb. but ive always told people for YEARS there is such thing as too much port area.
ever occur to you that that box is fked up as well? Might need to hire a proper box designer man. Give me the old box specs and i'll put that to the chopping block as well. I guess just because you say so means that no one else will get good results from using these cheap subs right?
10s playing 28hz with authority. OH look a box for 10s has the same port width as your box for two 12s. HOLY SH*T
U forget i asked u for help building the box? Yes i chose to go with a slot port instead of a cardboard tube? Funny how no matter what response i give its user error... Is it not possible that the subs just ****. Im gonna leave it at that. Im done asking for help or opinions. No matter what i chose to do i get sh-t for it. **** it ill take my sjitty subs and deal with it . end of conversation close the fluckin thread ban me. Kis my ask i been on this forum since 06 but i dont know shiznit. *** it im goin stock
Chill man man no need to get upset. The point most are making is that the subs are not shit because they have been proven not to be. They are capable subs just the box needs to altered some. To me your box seems a bit low on the tuning for them. Also you port aero for a slot port is really on the small side. Rule of thumb for a slot port is usually 12"s at the least, up to 16"s where as using a round port/aeroport most look for 8"s - 12's. To me the size of your box is fine but tuning is low and your port area is low from the specs you gave of your box.
And Trust me, if you would have went with a "cardboard tube/sonotube" and came up with the same amount of port per cube and raise the tunning it would probably sound alot better. I have been using the sonotubes from lowes for the last 3 years and they work just fine. Im currently using one as well
furbee86
furbee86
Aurora, CO (denver area)
Papermaker85
