I own a 2000 Subaru Impreza 2.5RS coupe and the thing I really like about the car is that it is lightweight, agile, and fun to drive. I've done moderate suspension upgrades to it and use it for spirited driving quite often. I am in the process of putting in some new speakers and want to give them a proper install. In the past I would lay thick layers of sound deadening on the doors, do the usual tricks, and call it a day. However, I don't want to add a bunch of weight to this guy.
What would you guys suggest doing to the doors to get the maximum amount of deadening for the least amount of weight added?
I checked out the sound deadening and you thread. I will be doing the following:
Egg crate foam
Clay around baffle
cover holes with sheet metal or plexi
Some sort of sound deadening
I guess my main question is how much would you say a layer of sound deadening on a door weighs? I don't want to add more than ~5 pounds to each door. Any other suggests are greatly appreciated.
Thanks guys
Egg crate foam
Clay around baffle
Thanks guys
