Sound Deadening Question
Am I OK with the Damplifier or should I go with the Damplifier Pro?
Is Pro worth the extra $$?
Thanks................
I'd say Pro is worth the money, but you'll be fine with either - you just might have to use a little more Damplifier than Pro.
Products like that are very effective at blocking nose - the main concern with floors. It's actually 15 mil lead sheeting composited with foam. 1/4" lead would weigh something like 16 lbs/ft² and e overkill //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I really think some manufacturers like to use "mills" because not a lot understand what it means. A quarter inch is 250 mills, boys and girls. Or should we be blaming the French......again...??...hmmm.....??.....//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
remember a curved surface is stronger than a flat one. so less deadner is needed.
And also less resonant, most likely. When someone recommends less "deadener", I cannot help but feel the happiness well up inside me....//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
magliteman
magliteman
Somewhere
FoxPro5
