yep SDS Tiles, STP Atlantic, and Knu Kolossusdammm 57 pages...
well i skipped to the end to see what was what. the only thing i got was........
"The top 2 after testing were Sounddeadenershowdown's CLD tiles followed by KnuKonceptz Kolossus 100mil with Kolossus being the overall best bang for your buck"
would love to know were the q-mat is in the list, as thats what i have in my truck.
when i get bored ill read more of it..
thanks.
Thats for deadening. For flex control, I'd go with tantric vibraflexthanks and ill read it.
goes to show i dont get on them forums... lol
maybe i sound do more often.
ok... did not know there was flex control stuff. i figured it was the same.Thats for deadening. For flex control, I'd go with tantric vibraflex
Its the same but the density and thickness is over the top. One layer is like two layers of other deadener So two layers of tantric will be basically like plywood/metal bracing.ok... did not know there was flex control stuff. i figured it was the same.
well i have about 40^ft of q-mat.
did both doors inside and out.
did inside on tailgate. need to do the outer tailgate but have to finish the welding/grinding.
put 1 sheet inbetween each roof rib. may just have to put more on.
i need to put some of the inside rear panels.
and what i put on the roof did help but.....
thats why i decided to ask here...
really dont want to do wood. only if i decide to do a wall. then ill do wood on roof.
yes what I linked on the other page. Same exact stuff. Different brand name. Is the deadener I had for sale.this ??
STP Black Magic Car Sound Deadener Vibration Dampener Foil Backed 36 Sq ft Black | eBay
if so any other place cheaper ?
ya was reading about that stuff and dammm that stuff is crazy thick.Its the same but the density and thickness is over the top. One layer is like two layers of other deadener So two layers of tantric will be basically like plywood/metal bracing.
ok it is 80 mil were as the q-mat is 87.8 mill.yes what I linked on the other page. Same exact stuff. Different brand name. Is the deadener I had for sale.Best for Restoration Noico Black Sound Deadener 80 Mil 36 Sq ft Under Carpet | eBay
wow great, thanks.I believe Ampere took over the Vibraflex
Ampere Audio Vibra-Flex Sound Deadener 21ft2 Pack
temporary solution for your current situation is basic deadening, dont have to go crazy, the stinger will work fine. However as your system gets bigger and bigger, You'd want flex control over basic deadening. Most 160 db cars fiberglass the body of the car to make it stiff along with deadening, stripper pole bracing etc..SO is there a difference between just standard deadening and doing flex control? should i be looking for something completly different from the rest of the car to do the roof?
