Sound dampining
this is going to be dumb Q:
how do you order CLD Tile from http://www.sounddeadenershowdown.com ??
If there is anyone who could possibly send me something to try. I am wanting to get something going very soon! I just don't know where to start. I'd like to see what a little on my door in my truck will change lol. but is there anyone here could could send a sample? I'd be 4 ever greatful!
Thank you to the guys who responded to my posts! I thank you alot. Thank you for what you will send me. If you decided you were going to send me something if you could send me the info thru pm as to how to use your products I'd greatly appreciate it
Not a dumb question at all since there isn't a shopping cart. E-mail me with what you need and a city and zip for shipping: don@sounddeadenershowdown.com. If you're not sure what you need, let me know what you are trying to accomplish and I'll help you figure it out.
Thanks for asking //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
or you could win a handful of tiles like I did at the GTG //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
The aluminum is definitely thick stuff, probably a good thing the "sheets" are so small because it might be a lot harder to cut than the normal stuff.
That's a good point. I've had no problem getting through them with heavy duty scissors or shears, but I wouldn't want to cut through 12 or 18" of the stuff.
has anyone seen or heard of elemental designs sound deadener? its 115-120 mils thick with 5 mils of foil would this work better than the sound deadener showdown cld tiles since it is thicker or worse because it has thinner foil?
http://www.edesignaudio.com/product_info.php?t=2&products_id=572
http://www.sounddeadenershowdown.com/products/cld
Thickness does not mean more mass, density is the key, and butyl composition. Not to mention, eDead uses a mylar foil, not aluminum, which is vastly inferior to alum. eDead is notoriously bad (it has a history of false specs, bad batches sent out anyway, and failed versions) and should be avoided. The SDS tile product is in another class altogether.
lovindabass
Banned
lovindabass
brooks,Ga
nineball
