Someone Help me build a Box...
Grim
Resident Electrician
Plllllleeeassseeee...
I will Pay for a good design...
(1) 18in Fi BL
Im looking for 8 cubes @ 32 Hz...
You pick the port area as Im not 100% sure on what I need..
I want Sub Firing up and Port back.
Preferably the type of port along the bottom of the box
Thanks guys
Duh....
Sometimes I want to kick myself in the ***...
I have the max dimensions right here written down as I went out to measure once again just for this post, and then forgot to include them
Max Width is 40in...
The rest I am lienient on...Id like to keep it under 17in Tall, so I can still use the rear cargo cover, however, I can go as high as 21in..(can go higher but need to see out the rear window untill i get my new rearview mirror monitor and Camera)
Depth, up to 30in....
so 40x30x??
Thats why there that small is because the opening is so much smaller than the cargo area...
My current box is 45x16.25x26
Here you go, this meets your specs.
8.1 cu/ft @ 32Hz 96 sq/in port
Well thats good to know, I didnt even think about that. But i was thinking more along the lines of output...8 cubes...i thought the port should be larger, but wasnt sure..
Anyone else? I think im going to stick with this design, but any input on things I can do to make it better...everyone always says, its all in the enclosure..
Grim
Grim
Western NY
Grim
