mylows10
B2,singer,ampere rep
Ok set the lp filter at 80. Subsonic at 20 get a bigger box. If your gonna use those subs. But get better subs Anyway. What car ?
20-80hz dosent seem like a wide range. Would that mean my 69's would b handling a lot of the Lo's? Like i say'd i see woofer that get up to 500hz, would that give me more Sub Action?dont even go to 100hz i would go to 80
I have a 2010 Jeep Patriot. An 20-80hz dosent seem like a wide range. Would that mean my 69's would b handling a lot of the Lo's? Like i say'd i see woofer that get up to 500hz, would that give me more Sub Action?Ok set the lp filter at 80. Subsonic at 20 get a bigger box. If your gonna use those subs. But get better subs Anyway. What car ?
That' s the plan, i was just wonder'n if any of it was worth keep'n. To CL they go, mylows10 has a sweet deal i need to jump onIf installed correctly and given enough space they will perform well, if you have the space for them. since you already have them you could run the L7's sell the 5s on craigslist and use that money to put back into the build.
Your subs aren't made to play frequencies that high. The 6x9s will handle those frequenciesI have a 2010 Jeep Patriot. An 20-80hz dosent seem like a wide range. Would that mean my 69's would b handling a lot of the Lo's? Like i say'd i see woofer that get up to 500hz, would that give me more Sub Action?
A wider range range sub is more of a mid that a sub and may not give you the lies you want or need Trust me the sub will be fineSo would a wider range sub give me more Whoomp????
80hz is more than high enough. I run mine crossed at 60hz and it works well with all kinds of music you wont even feel like your missing anything above that.
So will the shorter range give me a stronger attack, as opposed to spreading power over the whole 20-100hz?A wider range range sub is more of a mid that a sub and may not give you the lies you want or need Trust me the sub will be fine
Trust me it will sound great if installed properly the 6x9 speakers will take over where the subs lack in the mid bass frequenciesSo will the shorter range give me a stronger attack, as opposed to spreading power over the whole 20-100hz?
LOWS ARE 20-80 trust me, this is an optimum range for subwoofers.20-80hz dosent seem like a wide range. Would that mean my 69's would b handling a lot of the Lo's? Like i say'd i see woofer that get up to 500hz, would that give me more Sub Action?
