Someone help I KICK'd myself in the trunk SMH
L7 can get loud but you will need to build a custom box. Square 15's should have 4-5cu after displacement each.
Seeing that it only gets up 2 100hz, what can i do to assist with lo's. Look'n into cdt 6x9's, is that enough?
Clean Highs an Blood Shakin Bass hahaha but yea i want to shake stuff up. Not big on SQ lo's
What all equipment do you currently own, and what vehicle are you using? please be as specific with what voice coil configs on the subs and details along those lines.
there is a lot of missing information for us to be able to give you any constructive advice.
you do not want any woofer set to 100 hz get 6x9s or 8 inch mids for that.
So i cant set LPF past 100hz right? I have a 4cu 32hz box so my sub-son is set about 32-35hz an LPF is about 100hz. Is that correct????
O God, you dont want to know what im running. Just know im looking 2 order 4 cdt6x9's with a AmerBass VFL 150.4 an a VFL 4480 for Lo's. Hope to sound off soon
MakkMar10
Bangin on a Budget
MakkMar10
SoCal
mylows10
