some easy questions for you pros
95Prober
hi.
im going to tackle my first box in a while and just wanna make sure im prepared
i hope i can get some help, thanks!!
1. what is the concensus to the best "lenth" and the "distance apart" of the screws that puts holds the box in place?
2. will "any" type of caulking do for the inside of the corners? is there any brands to avoid?
3. what is the consensus to which brand glue to place between the pieces of MDF ?
4. im making a ported box. im going to round out the corners on the inside part of the port for better flow. should i make the curve a nice arc ? completely rounded and smooth?
5. im going to lightly sand the port with 220 grit then spray black enamel for looks. would that be ok?
6. the box is for (4) 12's. is it necessary to brace or double up the side where the subs mount?
im so sorry about all the questions! just wanna make sure of everything thats all
i appreciate any info!!!!!!!!!!!!!
hi.im going to tackle my first box in a while and just wanna make sure im prepared
1.) presonal prefrence. every 1 1/2" is ideal. and a 1 5/8" screw.
2.) Simple Silicone is what should be used. You can use silicone II if wanted.
3.) Any wood glue. Elmers/tightbond... Make sure it's WOOD GLUE.
4.) As round and smooth as possible. It does not have to be a perfect 90 degree rounded angle. Just get it as smooth as possible to reduce possible port noise.
5.) You really will not need to sand the port before painting. As it will not be very visable. But it will not hurt.
6.) A double baffle and bracing would be ideal. You want there to be no flexing of the panels. And depending on the design, that may be present.
Post a pic of the design.
LOLERS I didn't even realize I typed 1 1/2" for screw spacing. Thanks peeps.
4" was the ideal "consensus" on the forums for screw spacing.
sorry to ask, but ....
1. what "type of screw" do you use?
2. oh, i heard some people talk about weatherstripping. where would this be applied?
3. am i supposed to put something between the sub and surface of the box to make it seal better?
1.) Go to home depot, pick up coarse threaded drywall screws.
2.) Weather stripping is applied to the under side of the sub. Only if the sub does not come with a mounting gasket. It will ensure a air tight seal for the sub.
3.) See number 2 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
95Prober
95Prober
Canada
tRiGgEr
