I thought I knew what was up. I went behind my deck found the yellow 12volt power which was said to be the 12V+ Switched wire then when I went to ground the wire the isolaotr started to vibrate and put off fumes. Wouldn't the blue remote turn on act the same as a 12V+ Switched. Or is it wroth the 55 dollars to take it to the pro install shop near by and hope they do it in around an hour.
