Slot port on left, right or centered
  • 5
Are u asking this question because your contemplating a change in a specific vehicle, or as a general question? Since each vehicle is different, there's going to be a big difference.... (hence install dependant)....
What type of vehicle, what subs, what amp, and what's your goals?
Really just a general question out of curiosity. I will be making a box for daily and was just wondering if it really made any significant difference. Was debating on just going with the port on the side like normal or as I've seen other have the port span the entire length of the bottom. MDF is very expensive where I live so I won't be making multiple boxes.
Also say if I wanted to change my design from side port to center. If my original design was one left side 10'' wide port, 20'' long (no bends). If I wanted to make it center can I make the port 10'' wide in the center with two boards 10'' long as the port? Will that be the same thing?
889
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
732
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
909
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
KilluminatiDre
KilluminatiDre
Japan
KilluminatiDre
SPLBassJunkie
    May 21, 2024
    May 20, 2024
