Single sundown Xv3 15 or dual ? 12’s recommendations
The top question should be. How much are you willing to spend for subs/sub?
2x Sundown U v2 12" subs will be about $500 each new, so $1000. Unless you can find an old v1.
Incriminator audio has the Lethal Injection subs 1000watts rms, 12" for $300 each.
DC audio lvl 3 12s $350 each.
PSI audio platform 1 with 1000 watt rms upgrade $365 each.
IMO, the best bang for your buck would be IA Lethal injection 12s for $600+ tax.
If you're willing to fork out $1k get the Uv2 or the other options for a bit less.
PSI car audio platform 3 15" with upgrades to handle 3k watts. Or 2 PSI platform 2 12"s.
EXOcontralto uses PSI subs with Incriminator audio amps. Incriminator audio also has some sick subs. Personally, I have 2 IA death row 12"s and they hit hard AF.
Use 2 12 Platform 2 PSI SUBS there coils are top notch and you can keep upgrading or rebuilding them if ever needed upgrading prolly nor will have to be there so darn good made I. USA n hand built each sub to ur order specs... I did it n luv e, there x,ax is 34 n moves windy alot there underrated n can handle more than what psi rates em for aka woth the $
So I was talked out of going dual 12’s over a single 15 for low end… now I just can’t get my mind off a sundown xv3 15 or Zv6.
If I had the same power on a xv3 or Zv6 with correct box specs, would there be a drastic difference in bass?
No way 2 12s is more loud dbs n moves more air... Do two 12s over 1 15 b6 far 100% look it up
2 years late with the reply....
West1
West1
Los Angeles,Ca
    Jun 20, 2026
    Jun 20, 2026
