Cmon man. I know those specs arnt right... I'm here for input an opinions.... Dnt hold back how I haven't even decided yet if I'm gona build it or get a professional. But that all depends on the feedback I get... But Consider this. I'm a carpenter. I have all the equipment required to cut an glue... It's the maths Abt it I need wrap my head around.You go on and build THAT and put a RF 1500 BDCP on it... no comment
You need to let someone model your subs in Winisd to determine the net Volume/port area for your power level... then you can use any app you like to fabricate the box... I'm done... if you put up parameters I'll help... if not... I'm out... best offer you're likely to get... I'm not "being like that"... parameters ARE necessary for modeling your subs... I don't have "Bonecruncher" parameters in my wallet... LOL!Cmon man. I know those specs arnt right... I'm here for input an opinions.... Dnt hold back how I haven't even decided yet if I'm gona build it or get a professional. But that all depends on the feedback I get... But Consider this. I'm a carpenter. I have all the equipment required to cut an glue... It's the maths Abt it I need wrap my head around.
Sent from my MHA-L09 using Tapatalk
just learn enough to use winisd. You dont have to worry about the other stuff, just use torres or xplicit audio for that.I'm watching that video from the Link... I'v watched many of this guys videos.... This one is good.. I'm gona watch to the end... Cheers once again shredder.
Holy s$! Your tuned at 65hz, that's just a hole in a box my man. Your port area is kinda around where you might need to be, but you don't want a subwoofer box tuned to 65hz, holy geez. Depending on your goals it differs but I like my daily subs at around 30-35hz depending on each scenario. If you were competing, depending on the frequency of your vehicle you could be up around 40-50hz with a box that would likely sound like poop for music.This is what I'v come up with![]()
and not in a good way either.Holy s$! Your tuned at 65hz, that's just a hole in a box my man. Your port area is kinda around where you might need to be, but you don't want a subwoofer box tuned to 65hz, holy geez. Depending on your goals it differs but I like my daily subs at around 30-35hz depending on each scenario. If you were competing, depending on the frequency of your vehicle you could be up around 40-50hz with a box that would likely sound like poop for music.
Best thing for you right now is patience. Stick around and learn a little bit about the basics of subwoofer enclosures. Don't rush to build yet, because if you build what you have designed there it might make your ears bleed at best.
That box isn't glued except the front face which I doubled to 36mm because wanted it flush with the sub. Other than that the panels are screwed on for disassemble and reassemble, I knew that tweaks would need to be made so I prepared for it (thank God)Holy s$! Your tuned at 65hz, that's just a hole in a box my man. Your port area is kinda around where you might need to be, but you don't want a subwoofer box tuned to 65hz, holy geez. Depending on your goals it differs but I like my daily subs at around 30-35hz depending on each scenario. If you were competing, depending on the frequency of your vehicle you could be up around 40-50hz with a box that would likely sound like poop for music.
The closest I could get my hz down to was 40. Since my port comes out at the top of the box.... I'll have to play a little bit more with my top depth to get the right port width. Lol I am very determined right now.Dude I honestly would probably pay for box plans if I were in your position. You really don't have the experience necessary to design your own box yet. It's not as simple as you want it to be and it's probably the most important aspect of the build. Pay for some plans and you see how it's done and practice later. We can't give you all the knowledge you'll need in one thread. Plenty of people here have been doing this for years and don't even know how to design a box still. It's not an overnight skill by any means. Get some experience under your belt.
Isnt his port area too low by about 4 sq in per cu ft as well?Holy s$! Your tuned at 65hz, that's just a hole in a box my man. Your port area is kinda around where you might need to be, but you don't want a subwoofer box tuned to 65hz, holy geez. Depending on your goals it differs but I like my daily subs at around 30-35hz depending on each scenario. If you were competing, depending on the frequency of your vehicle you could be up around 40-50hz with a box that would likely sound like poop for music.
