single 18 in a single cab
NS is even better, they require less space than any other 18 i've seen, you can bring the height down a bit. for instance. You can do 60" long, 11" deep, 18.5" tall, if you use a single 8" sono-tube port @ 17.5" long assuming .5 ft^3 for sub displacement and bracing, makes for 5 ft^3 @ 34hz
Would the sub have to be firing out the side or what? The window line doesnt really both me
Here is my 2000 dodge, how can you get a 18" sub in there is beyond me. I have heard of 15's but not 18's.
no... new body style, the 2002+ i have no idea what you can get in the 2001 and earlier, never built a box for one
Im definiate I will have enough room for it. Worst comes to worst, I will have to remove my middle seat which is no biggie.
What is the standard mounting depth of a 18. I wanted to try one 15 firing forward on the passenger side. I did'nt realize that there was that much more room in the newer models.
from what i've seen, typically between 9.25" and 10.25" but thats just what i've seen thats not set in stone
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Hello, What amps should I use for this: 2xFocal Auditor Sub 12 Slim Focal Expert PS165v1 Can Focal FPX 5.1200 work or is too much?
Well the setup I mentioned cost around 1,000 USD in my country and an extra 500 USD for the DPS. HU? The car display? I plan to stay with original
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
471
Bobby322
Bobby322
TX
spencer321
    May 12, 2024
Brendon Jenness
    May 11, 2024
