single 18 in a single cab
****...so many choices. Budget needs to be under $400 and be able to fit in 5+ cubes
Hit up Rusty and see what you can get for $400. I'm not sure how much the LV3s or LV2s cost but either way I think you should go with 3-10s. 3 d1s can be ran at .67ohms (I think), which the AQ can handle just fine.
yeah i will. When are the new SA 8s comming out?
my electrical isnt that great so idk about .67 ohm
man your truck has way more space than mine, i could barely fit a box thats 2cubes sealed(no blow through) i got a silverado though.
yeah its got quite a bit of room, just doesnt like square boxes.
Thinking about going with 3 10s
I might do an 18'' nightshade //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
or some IA 187 10s
Dont be a retard who runs an 18 in a tiny space just to say they have an 18. Go for something like 3 12s.
3 12's would take 4.5-6 cubes... 1 18 would take... guess what... 4.5-6 cubes.
im guessing your talking about a dodge ram standard cab as its the only standard cab i know with that kinda room (i had one) if you wanna run a single 18, run a single 18, there is plenty of room. take the back panel off... break out the tools and remove the center seat belt track (otherwise you have to build a C-channel around it) you can go 60" across, 11" deep and 24" tall without messing up how far you can push your seats back. thats 10.25" of mounting depth and 7.23 gross cubic feet. 24" inches takes you right to the window line and not hair over it so you will not have to worry about not being able to see out your back window, enjoy
I wouldve but its D1 man.. and with my electrical right now I dont feel comfortable running .5 ohm daily on my 2200. a fried amp right now would kill my plans
haha true that but I dont think 2k on a 4k rated sub would be doing it justice. And I know NS work well in smaller boxs
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Hello, What amps should I use for this: 2xFocal Auditor Sub 12 Slim Focal Expert PS165v1 Can Focal FPX 5.1200 work or is too much?
Well the setup I mentioned cost around 1,000 USD in my country and an extra 500 USD for the DPS. HU? The car display? I plan to stay with original
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
467
Bobby322
Bobby322
TX
spencer321
    May 12, 2024
Brendon Jenness
    May 11, 2024
